01-08-2008 10:55 PM
01-09-2008 04:04 AM
It has an RS232 port and a USB port. You would use VISA to talk with the devices. Chapter 5 in the attached manual has the command structure. It comes with some software that looks like it will grab data. You could use portmon to watch the serial traffic to help reverse engineer the code. Download an existing VISA driver to see how they are setup. It basically amounts to setting up text strings to implement the available commands.
01-09-2008 04:31 AM
07-10-2008 04:26 AM - edited 07-10-2008 04:28 AM
Hello I am new to LabView
I use LabView 8.0 and want to read out the values from the aboved named system from Keyence. I use it with 2 laser to make the hight measuring of a coated film.
For this I want to use the RS 232 port from the Keyence measuring device I did all the wiring with the special connectors from Keyence. So its connected to my LPT1 port at my computer.
I use the standard example from the labview libary. The communcation works with VISA. This you will find attached.
I did all the configuration on the Keyence measuring device (Parity, data bits, baud rate ....) But when I want to send a string (For example "ASCR") like it is descripted in the manual I did not receive an value back. Why? The failure message is - 1073807339 I think this means a time out failure. The device is not responding or?
Did I forgot something or something important is missing?
07-10-2008 09:00 AM
Did you assume that the CR you see in the manual are the separate characters C and R? ![]()
The CR is explained in the manual and is a carriage return. In the example, the CR is the \r.
07-10-2008 11:16 AM - edited 07-10-2008 11:17 AM
06-08-2011 11:34 AM
I have a VISA driver working for the LK-G5000 using RS-232 but I can't seem to get the USB working. The USB doesn't show up in the VISA Session control. I have the Keyence\LkIF.dll installed as well as the \Keyence\KeyUsbDrv.dll.
Can I use VISA on this or is there another way?
06-09-2011 11:50 PM
Does the device still show up in Measurement and Automation Explorer when it doesn't show up in the VISA resource control? To be able to communicate with a USB device, you must be able to see the device in MAX under USB Devices. Please look at the following KB:
USB Instrument Control Tutorial - http://zone.ni.com/devzone/cda/tut/p/id/4478
Once you can see it in MAX, you can use standard VISA functions to communicate with the device in LabVIEW. You should also be able to communicate with the device connected by USB and call those DLLs from LabVIEW.
Jordan
06-11-2011 10:07 AM
No it doesn't show up in MAX.
Is there a work around for that. The thickness guage works fine using the rs232 but I'm told I have to make it work for USB. And it works fine with the Keyence UI through USB.
08-10-2011 09:45 AM
Hi, don't know if you are still working on this, but Keyence does not appear to provide drivers for the USB. They don't offer any sort of SDK for the LK unit that I have found, and linking directly to their .DLL library does not show any available functions. I suspect that is intentional - with Keyence it's been my experience that they like to hold their hardware/software development close to the vest. Their own software supports functions that are not available to an outside developer.
That being said, using the serial port is reasonably fast, and has a rich command set that will pretty much let you do any setup and data reading you can do from the front panel. It won't get you the 50k readings/second that the hardware is capable of, but there are workarounds for that as well.
