Key for focus in subpanel
No, the VI key events are registered only by the main FP containing the subpanels. However: after clicking into one of the string controls mentioned above one is able to tab through the subpanel then, but key events still registered only by the main panel, even then the tab events ...
Message 11 of 17
(415 Views)
As far as I can see this is *still* an issue with subpanes...nothing has changed since 2019, or? Not having keyboard navigation available just due to using subpanes seems quite silly 😮
Message 12 of 17
(113 Views)
This works.
Message 13 of 17
(95 Views)
Not exactly a tab-navigational experience that...but yes, if you e.g. do a key detection detecting the tab key, then check if the last (or prior one to the subpane's first) in the key order on the main has focus, you can send a message e.g. to the subpane-VI to put focus on its first control, then tab onwards from there. Then you have to do the reverse when getting to the last control in the tabbing order in the subVI to get focus back up to the main... 🙄
LabVIEW should handle this automatically based on the key order of the given subpane and whatever VI is on display there.
Message 14 of 17
(77 Views)
Here is a demo of the method I described (without the tab-navigation back to the main panel, but that would just be the same logic but in reverse...). Messy.
Message 15 of 17
(48 Views)
To have tab navigation between panels, this might be a simple solution:
Qestit Systems
Certified-LabVIEW-Developer
Message 16 of 17
(34 Views)
@Yamaeda: The subpane container itself does not need any key focus (in fact in most cases you do not want anyone to know about it anyway). But yes, the technique you show is the same as I posted, but with the exception that a notification is sent to the VI in the subpane to make it grab the key focus to its first control.
Message 17 of 17
(13 Views)
