Keithley 6221/2182A Delta Mode Example
I'm using ethernet for connection, and I put in the address that showed on the 6221 as it turned on. Is there a way I should modify the software to accommodate for ethernet instead of GPIB?
Message 11 of 14
(1,692 Views)
Accepted by Chong_X
Oh, for the ethernet address you need to use a port.
What do you write as the VISA address ?
(some Keithley 6221 firmware do not work with ethernet. Do you have the C04 fw ?)
For the visa address  you need  TCPIP::" ip address" ::SOCKET or is it ::INSTR ?
Do you see the device in MAX ?
Anyway, depending on the firmware, it may not work. You may wish to contact Keithley (I did, but not get any answer so switch to GPIB).
More details are here : https://forum.tek.com/viewtopic.php?t=33800
I found this problem in 2012 !
Message 12 of 14
(1,689 Views)
I'm just putting down the ethernet ip address for the visa address. It's something like 192.168.etc. I was able to find it and successfully validate the address in MAX.
I did try both ways of rewriting the ip address, but I didn't have much luck. I think at this point I'll try to switch to a GPIB cable instead.
Thanks for you help. Hopefully switching to GPIB will get me past this.
Message 13 of 14
(1,683 Views)
Hi bro.Did you make it by using GPIB? I am doing the same thing with you. I connected 2182A and 6221 with triggerlink and RS232 cable. Then I hope get the data from 6221's buffer by Labview, but there is something wrong with that. The error command is:Buffer data type is 'NONE', thus there is no data in buffer.Another error is -222, parameter data out of range.
Message 14 of 14
(637 Views)
