06-17-2022 07:19 AM
hello,
please I have a little problem in the conversion of (json to cluster and cluster to json) I want to convert <Json string> to cluster, to write information in it and I used the following program, then I convert this cluster again in json, but I'm not getting the ordered result like before.
Do you have any suggestions ?
06-17-2022 07:56 AM
The ordering of the cluster is used.
You can change it, by right clicking the cluster and choosing "Reorder Controls In Cluster".
You should also look into type definitions.
@CO2022 wrote:Do you have any suggestions ?
Yes, post the code not images.
If you post images, embed them in the text (saves us a download, open and delete).
