Join 2 modbus registers
Good Afternoon!
I have tried joining 2 modbus registers to generate a single floating type with decimal point. I am working with modbus tcp and I want to read the position of the encoder of a servomotor, everything works fine when the numbers are positive but when the position of the encoder becomes negative is when the problems begin. I am going to put an example. when my first modbus register is = 17615 and the second is = 7 (1 = 17615, 2 = 7) and together with the numbers it generates a number that if it is the correct position of the encoder (476367), so far so good. But when the encoder becomes negative, my first modbus register is = 24635 and the second is = 65533 (1 = 24635, 2 = 65533), it should give me a value of (-17.20) but labview generates another very different number. remove the main code and just leave an example with an array of 2 numbers which is exactly the same when modbus gives me the 2 registers. I've seen examples but they don't work for me, can someone help me?
Code Images Annex
(5,831 Views)
If you need negative numbers then you shouldn't you be using SIGNED integers?
What is the device and do you have a manual for it?
=== Engineer Ambiguously ===
(5,830 Views)
If you are expecting a value of -17.20, obviously all your "blue" solutions are out unless there is some scaling (or FXP interpretation) involved. As has been said, we simply need to see the manual.
(and if you primary number is integer, you probably want to simply change the indicator to I32 or convert to I32 for further processing. Do you know the byte order?)
(5,820 Views)
Accepted by BibianoFlores
@BibianoFlores wrote:
but when the encoder becomes negative, my first modbus register is = 24635 and the second is = 65533 (1 = 24635, 2 = 65533), it should give me a value of (-17.20)
Wild guess (you can change the 10k to SGL if you want a SGL result, but it does not matter for the value):
(5,814 Views)
Divide that by 10000 and you get -17.1973, I think that's probably it.
Edit: Was beat to it, the previous post wasn't there when I clicked Reply...
(5,813 Views)
Thanks Friend, It worked perfect. I appreciate your cooperation.
(5,793 Views)
Kyle97330
altenbach
Either of the 2 solutions worked great
(5,792 Views)
