Iteration question
Could I get some advise on how to build this...I need to take a number and add a constant to it, then take the new number and add the constant, so on for 401 iterations feeding to a 1D array. I know this must be simple, but I can't figure it out. Thanks.
Message 1 of 8
(3,990 Views)
Accepted by frakintosh
:dunno
Code attached.
If you want the input as element zero of the array, remove the [+1] between [i] and the multiply.
Message 2 of 8
(3,984 Views)
Try a for loop with a shift register.  Autoindex the outupt to get the array.
Lynn
Message 3 of 8
(3,983 Views)
Ohhh, nice let me try that tonight...Thanks!
Message 4 of 8
(3,970 Views)
 (drop a control onto the front panel and call it "Input")
 (drop an "Add" there, wire input to first terminal)
 (Loop of some sort, iteration multiplied by the constant)
 (wrap a for-loop around the whole thing, new control into the number-of-iterations terminal)
 (For-loops can easily auto-index, just bring the output of the add to the edge of the for-loop)
 (This is why graphical programming rocks!)
Message 5 of 8
(3,963 Views)
PERFECT...thanks for the quick reply and help SnowMule!
Message 6 of 8
(3,927 Views)
SnowMule wrote:
Code attached.
The terminal of the control labeled "constant" belongs before the FOR loop. There is no need to re-read it at every iteration, because it should probably not change while the loop is executing (if it would change, the results would be unpredictable).
Here's what I usually do. (if you like the +1 variation in snowmule's code, simply tap the wire after the "add" instead of before as shown)
There is also "ramp pattern", of course.... 😉
Message 7 of 8
(3,921 Views)
Yea; it's not "perfect" code, did spot some things like that to improve performance.
Didn't know about that ramp function... good to know.
Message 8 of 8
(3,903 Views)
