09-23-2007 05:18 AM
09-24-2007 12:56 AM
No, the tagsrv.exe still runs even after I quit LabVIEW. ![]()
Maybe something else...
09-24-2007 12:58 AM
I think it is something related to the DSC mobule.
Maybe Ben should explain...
Do you use LV DSC ?
09-24-2007 02:50 AM
I dont use LabView DSC. I found that my PC reboots I obseved in crash dump analyser that its because of access violation error. The process name reported to be either LabView or tagsrv.exe.
How can I avoid them from accessing an invalid or reserved memory space..
Thanks and Regards
Siddu
09-24-2007 04:05 AM
hi there
the tagsvr.exe is started by the service
"National Instruments Variable Engine"
This service handles the DSC-Tags and the shared variables. If you disable this service some applications may not work any more. What's your LV-Version and your OS? Is your OS up to date?
09-24-2007 04:27 AM
09-24-2007 04:55 AM
