Issues translating PowerShell to LabVIEW (finding Assembly & Error 3008)
@xingdx wrote:
hello
    i want to calculate the sha1 by powershell in vi,how can i get the feedback; i have achieved it by cmd,but the time by this method is too long;
thanks
Why use the powershell?
.NET can be used directly, and you'll get all the feedback you want. The data size also won't be a problem anymore, because you can stream your data into the SHA1 method.
Assuming .NET has SHA1 methods, but I'm pretty sure it does.
Message 11 of 19
(2,001 Views)
yes,i am try to find some .Net constructor to calculate the SHA1 or other HASH,but i am fail.
 Could you give me some help?
Message 12 of 19
(1,989 Views)
thank you for your help
Message 14 of 19
(1,979 Views)
wiebe@CARYA wrote:
SHA1 Class (System.Security.Cryptography) | Microsoft Docs
I had to use this one recently - this bit me:
if you want to calculate an sha1 hash, from within LabView, you need to start with "System.Core" not "System.Security.Cryptography"
Message 15 of 19
(1,959 Views)
yes
  when i used the System.Security.Cryptography,the feedback is :This assembly does not include any public classes that can be created ;
i am try to solve it in some method ,but up to now ,it is failed;
thanks
Message 16 of 19
(1,944 Views)
Hi Alex,
the example is nice, but you can replace the FOR loop by a simple ConcatString operation with just one input…
Message 17 of 19
(1,932 Views)
Well, obviously 😉.
In the msdn, change the Version to your .NET Framework, then the documentation will mention the assembly:
Message 18 of 19
(1,929 Views)
@GerdW wrote:
Hi Alex,
Kudos to you!
Message 19 of 19
(1,905 Views)
