Issues in understanding parallel computing in Labview
Ashaironix wrote:  other case at trhe same time logs it
Right there is your main problem.  In 95% of the applications I do, the logger has to be a separate process.  You can just have your consumer loop enqueue data for your logger.  Logging to disk just tends to be slow, so it really should be separate for that reason alone.
Message 11 of 11
(674 Views)
