Issue with Case Structure Input Tunnel
as an exercise .. enable highlight execution, put some probes on wires
and observe what happens with all the NOT "Number of Carrier" calculations
then it will become obvious
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 11 of 14
(736 Views)
Hi.
You have to fill in all data for all arrays that use autoindexing, or as a previous post said, the for loop won't iterate.
Try filling in data in all arrays...
Cheers.
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
Message 12 of 14
(730 Views)
I think I got your idea! Problem solved! Thanks!
Message 13 of 14
(723 Views)
please select the answer which helped you and mark as solution
Message 14 of 14
(719 Views)
