Issue with Case Structure Input Tunnel
In my project, I have to use arrays to input my data.
However, when connecting the array to case structure, it can only perform the true/false condition but not string and constant conditions.
Message 1 of 14
(5,024 Views)
not sure what your problem is, code looks (cleanable) but correct (as in should run)
 might be that your arrays have different lenght on the second forloop?
the loop should only execute as often as length of the smaller array
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 2 of 14
(5,014 Views)
Enable Highlight Execution and debug, if not sharing the code.
uday
Message 3 of 14
(5,008 Views)
In my diagram, I connected one of the arrays to a case structure for true/false condition and another one is for string condition. When I run my program, there is no output from the case structure that perform string condition. My friend told me that arrays can only perform true/false condition in case structure.
Message 4 of 14
(5,003 Views)
read up on the help (CTRL+h) of the case structure,
your frind is wrong
EDIT: i mean you cant connect an array directly, but for elements its wrong
Message 5 of 14
(4,992 Views)
Can you explain bit more clearly and post code?
-In the mean time you can Start with below links to learn about LabVIEW programming
NI Learning Center
NI Getting Started
LabVEW Basics
LabVIEW Graphical Programming Course
Using the Context Help Window
uday
Message 6 of 14
(4,991 Views)
Here is my problem. I can't get my output if i use array.
Message 7 of 14
(4,967 Views)
plz add some data,
fill your controls and then "Edit -> Make Current Values Default"
and then post again
by the way ... x*1 = x
Message 8 of 14
(4,958 Views)
Accepted by topic author hqoster123
There is no data in your arrays, how we are supposed to run and check?
-Populate the data to the controls and then make them as Data Operations-> Make current Values as Default and then upload the VI.
-You have used auto indexing with three arrays, and minimum size of those array determines the iteration for for loop. Read: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAghSAG&l=en-US
uday
Message 9 of 14
(4,957 Views)
Sorry, already make current values default.
It should have some values in the first three outputs but all zeros.
Message 10 of 14
(4,940 Views)
