Issue of low power of received signal of 802.11 application framework
Hi all,
I am recently start using 802.11 application framework. And the power of the RX received signal was too low and can't successfully transmit signals which can be viewed in the graph of RX Constellation and RX received signal. And I am using 2 antennas on a single RIO device of USRP 2943 of 40MHz, transmitting PN data. Many thanks in advance.
Guo
(2,262 Views)
Hi Guo,
Can you also include a picture of your configuration (the left side of the 802.11 panel)? And it would also be great to get a picture of your hardware setup as well. Would that be possible?
Cheers,
Michael B
Michael Bilyk
Former NI Software Engineer (IT)
(2,224 Views)
