Issue in connecting sub VI programs through the main program
ymanglik2009@gmail.com wrote:
Hello GerdW,
No-one is perfect in starting to learn something. Everyone needs help.
ymanglik
While that is definitely true, it seems that you don't want help; you want someone to do it for you.  You have all the tools, you have lots of advice.  It's time to step up... or step aside.
Bill
CLD
(Mid-Level minion.)
Message 71 of 92
(2,218 Views)
You've been given a lot of help but I'm not sure you taking advantage of it or following the suggestions. Have you tried my suggestion or did you just post to complain?
Message 72 of 92
(2,209 Views)
Yes I have tried a lot but I am unable to understand. Its ok thanks a lot for your help.
Message 73 of 92
(2,199 Views)
You are unable to understand how to open the VISA test panel in MAX? Right click on the device in MAX.
Message 74 of 92
(2,197 Views)
Hello everyone,
As I have already discussed about my program which is working well with positive values of voltage but not accepting negative values & in my experiment i have to give 0 to -200 V  bias voltage to the diode so I am not able to understand how to fulfill it. Which command should i use to do this or tell me any other method through which i can go for negative polarity.
please reply urgentlly!!!!!!
ymanglik
Message 75 of 92
(2,150 Views)
And have you tried the simple thing of using the test panel instead of writing more code? You need to do some simple debug and read the manual closer. Contact Keithley. Have you done that. It is their instrument and they should be able to tell you the proper command.
Message 76 of 92
(2,150 Views)
Hello everyone,
ymanglik
I don't understand.  Isn't the Keithley 2400 a meter?
Bill
CLD
(Mid-Level minion.)
Message 77 of 92
(2,128 Views)
Set 0-200V and change polarity of outputs.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 78 of 92
(2,110 Views)
/Y
You're talking about a power supply, right?  I just wanted to be clear because I am totally confused about what the OP is trying to ask.
Bill
CLD
(Mid-Level minion.)
Message 79 of 92
(2,106 Views)
Keithley calls it a SourceMeter. It is a variable supply with a built-in meter.
Message 80 of 92
(2,098 Views)
