Issue in connecting sub VI programs through the main program
Sir/Madam,
                   I have made a few sub VI  programs of 'Keithley 2400', but I am having problem in connecting them together through the main program. Actually the created sub VI programs are not showing  any activation button when I connect 'action.vi' file in 'read.vi' file (attachted).
Please give suggestions.
Yachika Manglik
Message 1 of 92
(4,606 Views)
You need to connect up your controls and indicators to the connector pane in order to have inputs and outputs for your subVIs.
LabVIEW Basics
LabVIEW 101
Message 2 of 92
(4,590 Views)
Thanks for quick response.
Can you please elaborate on how to connect the controls and indicators on the connector pane? Also where is the dialog box for the connector pane?
Message 3 of 92
(4,516 Views)
-I cannot see you vi because i have lv12 (try saving it to previous by File>>save for previous version)
-From crossrulz comment i thought this is where you are missing. Please check
https://www.ni.com/docs/en-US/bundle/labview/page/building-the-connector-pane.html
and https://www.ni.com/docs/en-US/bundle/labview/page/assigning-terminals-to-controls-and-indicators.htm...
uday
Message 4 of 92
(4,507 Views)
Thanks for quick suggestion.
I am sending you converted labview programs of version 12. Now can you elaborate how to connect controls and indicators on connector pane?
Message 5 of 92
(4,490 Views)
In continuing to first message , the attached files are here.
Message 6 of 92
(4,488 Views)
Yes, Did you follow my second link properly? That will exactly guide you how to connect controls and indicators on the connector pane.
-For example Please follow this link which shows how to connect controls and indicators to connector pane.
http://www.youtube.com/watch?v=OFfD59YSn3w
-Please connect the appropriate wires and it Will work.
uday
Message 7 of 92
(4,485 Views)
Hello
Thanks for your suggestion.
I have successfully implemented connections in my code according to your given suggestion .
Now I am facing problem to link a file named 'control1.ctl'(attached) that I have made for selecting option 'select type of action' and need to add' control1.ctl' in  'read.vi' file. It is showing  following error( below).
Error: " required input ' GPIB action' is not wired.
                 OR
           "Enumeric conflict"
So can you please suggest how this error can be removed?
Message 8 of 92
(4,458 Views)
Hi that's really great to hear.
-Will definitely help-please post it in lv12 please(I cannot see your vis)
uday
Message 9 of 92
(4,454 Views)
Hello
The converted version of VI's are attached here.
Message 10 of 92
(4,446 Views)
