Is there any method to plot a Graph and its regression line together in a single graph or chart.
Hello everyone..
This is just to know the different methods to plot a graph along with its regression line in a single graph, without using picture plot in it...
Message 1 of 15
(4,770 Views)
Have you read this topic on NI.com? I think it would work just right on your problem.
ʍolɟɐʇɐp ʞuıɥʇ
Message 2 of 15
(4,763 Views)
I think I do have small knowledge about stack plots from graphs and charts. Making multiple data to collectively appear in same plot isn't the matter. I think I have mentioned a word regression line.
As I have mentioned I need to plot a data, and plot its regression line too in the same chart or graph.
And this must be done without using Picture from Graphs and charts. As I already saw a solution from altenbach which explains about the same topic implemented in the above said concept.
Message 3 of 15
(4,741 Views)
Sorry if I didn't understand correctly.
As I understand you have two sets of data you want to plot:
1) some data
2) regression line for this data
So your problem is not about plotting the two graphs but calculating  2) from 1) ?
For that you only need the linear fit VI from the maths palette.
Best regards.
ʍolɟɐʇɐp ʞuıɥʇ
Message 4 of 15
(4,721 Views)
yup.. Is there any-other method too?!
& similarly is this (above mentioned plot) possible in LabVIEW.. i.e.,I need to
put every plot with different color's in order to differentiate column corresponding
data.
Message 5 of 15
(4,717 Views)
Of course you could create your own algorithm or maybe you find other 3rd party functions. But I think in most cases the in-built LabVIEW functions are the best option. So why would you want another method?
data.
Yes this is possible in LabVIEW. I would go for a saparate plot on an XY-graph for every column. The tricky bit is to create and locate the black numbers on the columns. AFAIK there is no in-built function for that in the graph indicator.
Best regards
ʍolɟɐʇɐp ʞuıɥʇ
Message 6 of 15
(4,696 Views)
It it possible with annotations within an XY graph!
Regards, Jens
Kudos are welcome...
Message 7 of 15
(4,692 Views)
@jg69 wrote:
@crabman wrote:
 AFAIK there is no...
Regards, Jens
Oh that's neat, thanks!
(again what learned Smiley LOL)
ʍolɟɐʇɐp ʞuıɥʇ
Message 8 of 15
(4,685 Views)
Yup, but it gets loaded up diagonally and am not getting a good procedure to plot the bar-plots as given below. Every column signifies different plots with some trick hidden inside them.
Message 9 of 15
(4,677 Views)
Maybe you can share your code, if you want help on that?
Best regards!
ʍolɟɐʇɐp ʞuıɥʇ
Message 10 of 15
(4,669 Views)
