08-31-2005 07:41 PM
08-31-2005 09:06 PM
Hi JShaw,
To answer your first question: yes. It is implemented quite often.
If you have not yet purchased a barcode scanner, let me recommend a wedge-type scanner as it is the simplest to implement.
I have implemented serial barcode scanners from Symbol. Basically, you communicate or rather read it as a serial device. That means the port has to be configured, transfer speed, etc. Actually, the process of initialization should be described in the owner's manual. I don't know if there are examples posted in the forum. The last time I worked with a serial barcode reader was in 2002 (?).
JLV
08-31-2005 09:26 PM
Serial barcode scanners are very easy and you don't have to worry about the wedge seeing a barcode at an inopportune time and having it enter in extraneous data where ever the cursor happens to be sitting at the moment. When the scanner sees a barcode, it scans it and spits the ascii string out to the serial port on the computer. Your program reads the data fro the buffer when it sees there is data present to read (the bytes at port serial property will tell you that).
Last driver I wrote to do this took about 30 minutes... Including creating a user interface for it.
Mike...
09-01-2005 08:28 AM
09-01-2005 08:38 AM
Hi Dennis,
I haven't tried newer USB barcode scanners. If I read correctly, you are saying that they are easy to implement as well? That's good. I would prefer USB over both wedge and serial-port types.. Personal preference, maybe, but there is more flexibility when using USB devices.. 😉
JLV
09-01-2005 09:11 AM
09-01-2005 10:15 AM
