Is there any LabVIEW program that allow me to read differential voltage from a full-bridge strain gauge that is attached to SCC-68 connected to a USB-6251?
I am a beginner in using LabVIEW and NI DAQ devices. I would appreciate any information that can help me to perform the following task:
I have an USB-6251 and an SCC-68 attached to it. I would like to use the screw terminals on SCC-68 (not modules), connect full bridge strain gaiges to them and read the voltage from them using the differential voltage method. My USB-6251 is connected to a PC that has Windows XP and LabVIEW. I was wondering if there is any program already written in LabVIEW that can perform this task? How can I find such programs? And finally, how can I find out how to connect the wires to the SCC-68 screw terminal?
Thank you,
Ardavan.
(2,562 Views)
M Series User Manual
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(2,560 Views)
In addition to the above, which is a very good place to start, make sure you install DAQmx, which are the drivers for the DAQ device. That will install lots of examples, which you can look at. I would also suggest spending some time here: Getting Started with NI-DAQmx: Main Page
(2,541 Views)
