Is there a way to tell if a subVI is used by another vi?
LabVIEW NXG.
If I create a VI and use it in another VI and then someone else edits my project six months from now is there a way that the person new to the project can tell if a subVI is used somewhere else?
I see that you can tell what sub VI's are called by selected "Show Hierarchy". I want to go in the revers direction. I want to see what calls a certain VI.
(1,820 Views)
if it's in a project, you can select the subVI on the block diagram and hit CTRL+F to search for instances of that VI.
You can also right-click the VI within the project and select Find>Callers.
(1,812 Views)
In standard LabVIEW (don't have NXG, sorry) you can right-click a VI in the project and click "Show callers" to tell you what calls a given VI. Note that this only works within a single project though, as it's the project that tells you where a VI is used, not the VI itself.
If you need to lock something like this you can put it in an .lvlib. I assume those exist- or something like them- in NXG.
(1,811 Views)
Ctrl + F works.
Right button clicking on the sub VI in project view does not:
(1,777 Views)
