Connection to Oracle Database with Labview
I have been trying to connect with an Oracle Database with LabView but I'm still unable after some days. I have read almost all the Post from NI regarding this topic but still did not make it work.
I can connect to the database with SQL developer from Oracle, so the connection is good (picture attached).
After that I try to connect with ODBC 32 bits driver from Oracle (driver installed: Oracle in instantclient_19_8) , but the configuration is requesting the TNS service, I try to fill this field with the hostname and the service name but did not work, so I suppose I don't have this information.
I also try to build the connection string using the samples from connectionstring.com but the OBDC samples request the TNS service, I didn't find an option to use the host and the service.
can you give me more guidance to make it work with the information that I have
Regards
LF
(2,636 Views)
Accepted by topic author LuisFuentes
I just make it work
I had to add the hostname and the service name together in the TNS field
Like this:
Hostname/Service name
I will close the Post
(2,623 Views)
