Is there a way to store state of dynamically loaded vi without resorting to subvi tricks?
I have a VI for opening a UDP connection, retrieving data, and then closing the connection:
Setting state to 1 opens a UDP connection.
Setting state to 2 retrieves a UDP package. Most boxes above is for data manipulation.
Setting state to 3 closes the UDP connection.
Now, calling this vi as a subvi works just fine:
But, calling the vi dynamically doesn't:
The second call inside the while loop raises an error. Apparently, referenses are not valid from one call to the next when calling a dynamically loaded vi. What I need to know is, is there a convenient way around this?
Lars Melander
Uppsala Database Laboratory, Uppsala University
(3,136 Views)
Accepted by LarsM
Calling dynamically a VI inside a while loop may be pretty bad in terms of performance and I'm not sure that's a good idea.
But if you really want to do this, using "Call by Reference Node" function should be more appropriate in your case (you will find some example easily).
Best,
J.
(3,130 Views)
Worked perfectly, thank you.
Making the dynamic vi reentrant makes performance decent.
Lars Melander
(3,115 Views)
