Is there a way to make text visible or invisible
I know controls and indicators can be be set to be either visible or invisible with property nodes, but is there a corresponding way to do this with text boxes?
(4,954 Views)
Why don't you use the 'simple string' under 'Classic Controls'? Just change the color and it'll be just like a text box.
(4,954 Views)
You will need to still use a control instead of just text on the front panel. Use the simple string control from the Classic Controls palette (without a label) and set the backround color to Transparent. Then it will be just text that you will have a Visible attribute that you can use to hide it.
Best Regards,
Chris Matthews
(4,954 Views)
You can get to plain text that you write on the background, but it's not
fun... it's the same as any decoration... I think you create a property node
referencing the front panel, then you create a sub-property node (that's
what I call it) for decorations, then, I think you use array subset to
select which decoration you want and then you create a property node
selecting visibility...
But, why not just use a "classic controls" simple string indicator and make
the frame transparent? Then you can actually change the text too... or
not...
Good luck...
nikb wrote in message
news:5065000000080000008C570000-1027480788000@exchange.ni.com...
> Thanks
(4,954 Views)
