Is there a property node that can affect the write speed to an indicator on the front panel?
I think a very simple solution to this is to setup your front panel vi in an event structure and have the front panel update as a timeout event you set for x # of seconds.
I usually use some modification of the consumer/producer template in labview to start the front panel stuff.
Message 11 of 12
(474 Views)
Hi IEC,
nice solution, but where can he write all values to the file now?
Mike
Message 12 of 12
(471 Views)
