Is there a keyboard shortcut for "pause" and "resume"?
I searched carefully but could not find such a shortcut. Is there a keyboard shortcut for "pause" and "resume" on the LabVIEW window?
(7,154 Views)
If its for debugging purpose, use Breakpoints..
https://www.ni.com/docs/en-US/bundle/labview/page/managing-breakpoints.html
(7,152 Views)
It is not for debugging purposes.
(7,150 Views)
Hi Finkler,
so then you should explain what you're talking about!
Which "pause" and "resume" do you mean?
(7,144 Views)
I run a VI by pressing the "Run" button (or Ctrl-R). After some time (nevermind why) I need to pause the VI. I typically do that by pressing the "Pause" button. Since I'm running this remotely from another computer, I would like to be able to press this button using a keyboard shortcut. Afterwards, I press the "Pause" button again to resume the VI.
(7,141 Views)
Accepted by Finkler
Hi Finkler,
so you are using a debugging feature! And no, there seems to be no shortcut key assigned.
When you need a VI with the ability to "pause" you should learn about state machines. They are a common scheme to incorporate such "states" as "running" or "paused" in a VI (or program in general)...
(7,137 Views)
