Is there a SQL VI for macs?
Hey folks,
I emailed customer service about this issue but they had no answer and said to post it here. I have the VI that comes with the database connectivity toolkit that does SQL transactions. I am looking to run the program on a mac, but have not found a working equivalent VI for macs. The tenative solution is to run a C program from labview to do it, but we are trying to avoid the extra layer. Please let me know if such a VI exists.
Thanks!
(3,153 Views)
The extra layer exists anyway because the DB toolkit VIs use ActiveX. You can try searching for LabSQL, but that might be windows specific as well, and it's not a finished commercial product.
___________________
Try to take over the world!
(3,147 Views)
Anyone have any other ideas?
Final desperation bump...
(3,133 Views)
Nothing specifically, but you should definitely google for some example code if you're not sure where to start 🙂
Best Regards and Best of Luck developing!
JLS
Best,
JLS
Sixclear
(3,118 Views)
The new Mac OS is basically a version of Unix (or is it Linux) in either case, there should be interface libraries available for those platforms that you can leverage. For example, if you were to write a program in C on a Mac to talk to, say Oracle. What interface would you use? You might be able to access the same library functions from LV.
Also, I seem to remember reading something that ODBC is now cross platform. Perhaps that might help.
Finally, can you use VI server on one platform (Mac) to run a VI residing on another platform (Windows)? If so you could write an application server -- which is not a bad idea anyway -- in Windows and your Mac application doesn't need to worry about how to talk to the database, or what kind of database it is, or the database structure, or a lot of other stuff...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,108 Views)
