Is ther a patch to allow using Vision Builder 6.1 with LabView 7.1?
I am currently using Vision Builder 6.1 with LabView 7.0.(thanks to a patch I found here).
Is there a simular parch for LabView 7.1?
(2,672 Views)
In order to use Vision with LabVIEW 7.1 you will need the Vision Development Module 7.0. The upgrade to Vision Builder 6.1 is Vision Assistant 7.0. Vision Assistant 7.0 is included with NI Vision Development Module 7.0. Your Internal Sales Representative or your Field Sales Engineer should be able to assist you in upgrading.
Doug K.
Application Engineering
(2,672 Views)
