Is it possible to wire a 1D array single to a numeric indicator or what would be the easiest way to display numeric values from the array on the front panel?
Is it possible to wire a 1D array single to a numeric indicator or what would be the easiest way to display numeric values from the array on the front panel? Any suggestions or examples would be greatly appreciated.
uddy
(3,166 Views)
Right click on the Array wire on the Block diagram, select 'Create->Indicator'
Ton
My LabVIEW Ideas
(3,164 Views)
Thanks Ton.  Can this indicator be setup to update continuously while the vi is running. Similiar to a numeric output wired to a numeric indicator. Do I need to tie it to a loop somehow?
Uddy
(3,153 Views)
Hi uddy,
To get an indicator update you will have to have it in a loop.  Every time the loop iterates it will update the values in the indicator.
Adam H
Applications Engineer
(3,115 Views)
Accepted by uddy
Thanks Adam, It was originally in a while loop, I placed it in a for loop, wired the count to the for loop and presto, it wires to a numeric indicator. It's working great. Thanks for the help folks.
(3,089 Views)
Then please mark the reply that most helped you as the accepted solution, not your own.
(3,071 Views)
