12-18-2007 05:43 AM - edited 12-18-2007 05:44 AM
The TCP Guide: Serial Line Internet Protocol
Point-to-Point Protocol
Wikipedia: Serial Line Internet Protocol
Point-toPoint Protocol
You are essentially creating an IP bridge between two devices. You can then send anything over this interface that you would send over an Ethernet cable, but of course much slower. You can use the UDP/TCP (and presumably VI Server) functions in the same way; just change the IP address from an internet address to the IP of the SLIP device.
While putting this together, I was reminded that the past holds many great solutions or "nuggets" for solving problems. Specifically, the Wikipedia SLIP entry noted that there is a Bluetooth protocol that essentially uses a version of SLIP.
12-18-2007 05:53 AM - edited 12-18-2007 05:54 AM
Nice post Philip!
You wrote "... the past holds many great solutions ..."
Let me paraphrase something from proverbs.
"A wise man goes into his storehouse and brings forth treasures both old and new."
Ben
