Is it possible to put a normal VI front panel in front of Modal VI front panel
I have a main VI that call 2 subvis dynamcally. One with default front panel say subvi1.vi and one with Modal front panel say subvi2.vi. Is it possible to put a subvi1.vi in front of subvi2.vi. Any property we can set to subvi1.vi's front panel? My requirement is somewhat different.
You might suggest :Making subvi1.vi as modal to open it over subvi2.vi. This is not an option for me because priority should be given to subvi2.vi only. Subvi1.vi is just a window that opens for some time and has no functional purpose.
-devashri_AMT
(2,666 Views)
Hi devashri,
no, modal windows stay in front of "default" windows.
You can place those windows next to each other by changing their positions/size dynamically.
Or you could use subpanels to display the frontpanel of "subVI1" inside the frontpanel of "subVI2"…
(2,651 Views)
The modal window A should probably be a normal window, the other (B) a floating window. That way, B will be on top of A...
(2,576 Views)
