Is it possible to map EL2809 using LabVIEW?
I'm currently new to LabVIEW and I would like to solve this question. I'm using cRIO-9022 and EtherCAT EK1100 with EL 2809. Is it possible to map EL 2809 using LabVIEW? Or do I need to use other software like workvisual?
(2,417 Views)
Generally speaking, you need the following software installed on your host PC:
LabVIEW Real-Time
CompactRIO
EtherCAT
You also need to install EtherCAT to cRIO-9022. Please refer to the following manuals for more details:
http://zone.ni.com/reference/en-XX/help/372626P-01/indcomecat/getstartedwithecat/
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9CqSAK
For third party slaves, I would recommend having a test on the compatibility.
(2,375 Views)
