Is it possible to make a collapsible front panel object?
Hi all,
Below is a picture of my front panel.
The right panel ('Haptic STM Controller') shows important information and controls that I want to be visible at all times. The left panel ('Addons'), however, doesn't really need to be seen more than once on startup. I was wondering if there was some way to collapse/expand the 'Addon' section on a button press? Scrolling to it works fine, but either means the section is cut off (adding clutter) or not immediately visible.
It's most definitely a first-world problem, but I was just wondering if it's possible since I couldn't find anything about it online. Any tips would be greatly appreciated.
Thanks!
(2,429 Views)
First of all, a functional, efficient front panel should be a design goal, so your request is not unreasonable.  Have you considered making it a subVI to be called with its front panel visible during initialization (and whenever else you feel like calling it)?
Bill
CLD
(Mid-Level minion.)
(2,421 Views)
Accepted by mpfreeman
Check this out. I've never gotten a chance to use this, it's just a "LabVIEW Useful Snippit" from an old coworker.
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(2,418 Views)
This is very cool, thank you!
(2,403 Views)
Echoing Billko, and noting you said your Front Panel Object is there during initialization time (when, presumably, you are not yet using the other right-hand panel), have you thought of making your Initialization routine (and its Front Panel) a Modal VI?  This, by design, means that it "pops up" in front of other Windows (I usually set the Screen Position for my Modal Initialization VIs to be Centered), and disappears when you push its "OK" (or "Abort", or whatever Buttons you are using to say "I'm done with you, now exit and pass out the Information you gathered").  You can find the Modal button on the right side of the Window Properties (if my memory serves) for your Initialization VI.
(2,328 Views)
I think this approach is much cleaner, simpler, and "expected behavior".
Bill
CLD
(Mid-Level minion.)
(2,326 Views)
My posts sometimes tend to be terse to the point where there are maybe not quite enough words to convey the intent of the post.  What I meant to say is that the method that Bob and I are suggesting (open a subVI with the front panel shown, and modal, close when done) is cleaner, simpler (no fancy front panel manipulations) and "expected behavior" - meaning that usually when someone wants to configure a setting, a dialog pops up that shows configurable items.  The LabVIEW "Options" dialog is a good example.
Bill
CLD
(Mid-Level minion.)
(2,294 Views)
