Is it possible to invoke other software applications in labview?
Is it possible to invoke other software applications in labview? I would like to upload my files processed in Labview to my web based database. I have no basis of FTP and SQL. Providing that I have no Internet Database Toolkit installed in my computer. So, is it possible to "call" the software in Labview, just like calling a function or sub VI?
(3,209 Views)
Hi
You can using ActiveX container.
But it is quite tricky.
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(3,209 Views)
If your other software is an exe, you can use the SystemExec vi found under the Functions - Communications palette. It will call any .exe program.
- tbob
Inventor of the WORM Global
(3,209 Views)
Hello kaykeat,
It is definitely possible to call other applications inside LabVIEW. Please see the links below for more help on the most common ways to call external programs.
If the code is a shared library:
Using External Code in LabVIEW
When calling an activeX method:
ActiveX and LabVIEW
Hope this helps in development,
Matt F
(3,209 Views)
Can someone be more specific? I'm trying to call WinTest 4.1 in LabVIEW and simultaneously do some image acquisition via the IMAQ VIs. I need to sync the video with the WinTest Data in the time domain so the program and the camera times match exactly. I'm having using LabVIEW to open WinTest and am not really sure how the System Exec VI or ActiveX stuff really works
(2,807 Views)
