Is it possible to have a reference to an object?
LabVIEW Class. Is it possible to have a reference to an object? Is it possible to get a reference to an object and execute methods from the reference? Thank.
(3,189 Views)
Accepted by topic author dgd.gomez
See Data Value Reference
If that's not enough, explain what you're trying to do in more detail.
(3,179 Views)
An object is a cluster of data. So you're asking if it's possible to call a method on a cluster of data by reference. As mentioned already, the closest thing to this is via a data value reference.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,153 Views)
