How do I find the max and min value for each column of a 2d array?
For example in the attached array max/min for the first three columns would be 45/23,   14/10,   80/67.
Thank you
(4,709 Views)
Accepted by topic author chuck72352
Chuck,
With the color on your bars, you should have enough experience to figure this out.  Smiley Wink
You are looping through the array already.  Now you just need a function like Array Max and Min. in the loop.  And perhaps you might need to Transpose the 2D array.
(4,707 Views)
Thank you. My solution is attached.
(4,698 Views)
Do not wire up both the N terminal and use auto-indexing.
(4,687 Views)
Done with suggested improvements.
Thank you.
(4,679 Views)
Your FOR loop on the bottom still has N wired while use the autoindexing.
Plus, are you sure you want your shift register uninitialized?  Your array will just keep growing. (I don't know how you plan to use this VI, so I'm just pointing it out as something to watch out for)
(4,658 Views)
