This widget could not be displayed.
Is it possible to edit multiple column listbox on the run?
I can't enter data in cells of a multiple column listbox on the run.
But I can edit them on the edit mode.
How can I enter data in the cells on the run?
(3,354 Views)
Accepted by topic author iCat
try it using a table ...
(3,349 Views)
or this way
(3,345 Views)
write to property node "item names"
(3,335 Views)
I manually entered data in cells of the table on the front panel, but the values are not returned in the block diagram.
How can I solve this problem?
Correction // It appears that I was misled to think so.
The data were returned fine.
(3,332 Views)
