Is it possible to edit multiple column listbox on the run?
I can't enter data in cells of a multiple column listbox on the run.
But I can edit them on the edit mode.
How can I enter data in the cells on the run?
(2,940 Views)
Accepted by iCat
try it using a table ...
(2,935 Views)
or this way
(2,931 Views)
write to property node "item names"
(2,921 Views)
I manually entered data in cells of the table on the front panel, but the values are not returned in the block diagram.
How can I solve this problem?
Correction // It appears that I was misled to think so.
The data were returned fine.
(2,918 Views)
