Is it possible to create a 1 D array with the "build array VI"? when receiving random number
Hello all,
Is it possible to create a 1 D array with the "build array VI" when receiving random number?
I am receiving random data and the build array VI always create a 2D array which might cause some problem if you want to compute certain type of operation after.
Any example will be welcomed.
Thank you,
Israel
Message 1 of 16
(4,110 Views)
Build Array (technically it is called a "primitive," not a VI) generates an array at the output which has one more dimension than the inputs. So it sounds like at least one of your inputs is already a 1D array.
Please post your code so we can see what is happening.
Lynn
Message 2 of 16
(4,107 Views)
r-click the Build array and select Concatenate input.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 16
(4,104 Views)
Hello Lynn and Yamaeda
First I want to Thank you Lynn for your linguistic contribution indeed "Build Array" is a primitive and not VI, thank you for the education. In reality what I am doing is simple.
I have two arrays of complex elements Array1 and Array2.
Array1 conains the complex elements ""(a0+ib0) ; (a1+ib1) ;...(an+ibn) ;
Array2 conains the complex elements ""(c0+id0) ; (c1+id1) ;...(cn+idn)
What I want to do is the multiplication of the first array by the  conjugate of the second array element.
Array1*(Conjugate Array 2)" for the first element the results is "(a0.C0-b0.d0) + i(b0c0-a0d0)" and the etc...
and then taking the square root ([(a0.C0-b0.d0) power of 2]) +  [(b0c0-a0d0) power of 2])
I was wondering if there were some dedicate primitive that could solve the computation above which is the cross correlation in Frequency domain.
Thank you very much.
Israel
Message 4 of 16
(4,063 Views)
The functions on the Numeric palette are polymorphic. That means that they will accept multiple datatypes. For your case you benefit twice. The work on complex numbers and arrays of complex numbers. The Complex subpalette of the Numeric palette has a Complex Conjugate function.  RMS.vi is in Mathematics >> Probability & Statistics palette.
I did work though the math manually to see if the answers are correct for the arbitrary values I chose.
Lynn
Message 5 of 16
(4,049 Views)
Is this useful?
Đặng Huy Hoàng
Message 6 of 16
(4,026 Views)
@Hohohihijj wrote:
Is this useful?
Don't overcomplicate things! You are using way too much code. Everything in the red box could be replaced by a single "absolute value" function. Try it!
(I think there are further simplifications possible....)
Also, why are you using CXT and EXT? CDB and DBL are sufficient in most scenarios.
Message 7 of 16
(4,015 Views)
Thanks a lot.Smiley Very Happy
Đặng Huy Hoàng
Message 8 of 16
(3,991 Views)
Hello Guys,
Your help is amazing, but I will do, If I want to do the following operation (a*a+b*b) power 0.75 or other value. Thank you to all you.
Israel
Message 9 of 16
(3,969 Views)
@israel.haifa wrote:
Hello Guys,
Israel
Square and Power of X should do it, no?
/Y
Qestit Systems
Message 10 of 16
(3,944 Views)
