Is it possible to control the number of elements read from queue
The data write into the queue follows the format of
(Data Length) + Data Block + (Data Length) + Data Block + (Data Length) + Data Block
When I read the data, need to read the Data Length first, then can read one Data Block.
Is there any function  in queue to do it?
(2,810 Views)
Hi turbot,
"Is there any function  in queue to do it?"
No, but there is the FOR loop to fetch datalength elements from the queue.
Or use the "flush queue" command the empty the queue - but you have to parse the element array afterwards...
(2,799 Views)
Accepted by topic author alex.
You can only dequeue data in the same form as you enqueued them. So, if you enqueue 3 data blocks at once (in which form? String? Byte array?), you will only be able to extract all 3 blocks at once; you later need to parse the extracted data accordingly.
Paolo
(2,793 Views)
