Error: labview run engine 8.5 not found on the system
I am getting the error attached when ever i click on additional installer. How to resolve this?
kavitha
(2,896 Views)
You can download the run-time engine (google run time engine 8.5 site:ni.com) and install it on the computer.
Felix
(2,893 Views)
When i try to install it is showing higher version is already installed(attachment 1.jpg) and when  i searched it is showing as in attachement 2.jpg
(2,886 Views)
If a run time engine of higher version like LV 8.6 is installed you cannot install runtime engine of Lower versions.
Inorder to remove runtime engine of higher version follow the operations that i suggested here
Post back for queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,875 Views)
