Right now the increment of my knob is constant( the increment is 1 in my attached code). Is it possible if I want the increment to be variable such as 1,2,4,8 when the knob is in different positioin? so my knob can output data 1,2,4,8,16... instead of 1,2,3,4. Thanks.
Thank, it works. I just got another problem. I use two radio buttons to control the same knob (shown as attached). I can change the properties of the konb to get different ranges something. How can I control the 'label' you showed in your code? Thanks.
You can use the "text labels[]" property to rewrite the labels. I'm sure there is also a way to rewrite the associated values, but I can't find it at the moment so I index into the array of values. See attached (LabVIEW 7.1).
(You should only rewrite properties whenever the radio button changes, not with every loop iteration.)
