Is it possible to control the increment of the Knob?
Right now the increment of my knob is constant( the increment is 1 in my attached code). Is it possible if I want the increment to be variable such as 1,2,4,8 when the knob is in different positioin? so my knob can output data 1,2,4,8,16... instead of 1,2,3,4. Thanks.
(4,472 Views)
Yes, right-click on the knob and go to "properties...text labels". Uncheck "sequential values" and enter e.g.
label="1", value=1
label="2", value=2
label="8", value=8
etc.
See attached example (LV7.1).
Message Edited by altenbach on 03-27-2005 09:42 AM
(4,470 Views)
Thank, it works. I just got another problem. I use two radio buttons to control the same knob (shown as attached). I can change the properties of the konb to get different ranges something. How can I control the 'label' you showed in your code? Thanks.
(4,461 Views)
You can use the "text labels[]" property to rewrite the labels. I'm sure there is also a way to rewrite the associated values, but I can't find it at the moment so I index into the array of values. See attached (LabVIEW 7.1).
(You should only rewrite properties whenever the radio button changes, not with every loop iteration.)
(4,448 Views)
