Is it possible to control 2 input for a similar output?
Just for simple understanding,
I have 2 forumla, a+b=c and d/c=e, 'a', 'b' and 'd' are to be key in while 'c' can either be key in or be found using the 1st formula
How do i control if 'c' is keyed, just use 2nd formule else use the 1st forumula
(2,970 Views)
Do you want to make the choice between a derived C and a keyed in C available by user action, like a switch?  If so, use a case structure.  Wire the switch to the case selector.  In True case, put in formula a+b and wire output to case edge.  In False case, put in a dialog box to capture user input, and wire the output to the case edge, same terminal as True case.  C will be whatever comes out of the case edge terminal.  The switch will dictate which method you use to get C.
- tbob
Inventor of the WORM Global
(2,959 Views)
There are several ways to do this.
Right off the top of my head simply use a boolean control to select if C is user input.
If you want to make it automagic use a string control and if C is not a number (or empty) use the built in C
Message Edited by RTSLVU on 05-13-2010 12:41 PM
=== Engineer Ambiguously ===
(2,955 Views)
Nice thanks. Just tried and it works. But is there any way i can do without the switch because in my case, there is more then 2 formulas. I don't really want the user to see too many switch
(2,935 Views)
Hi badbadtzmaru,
you don't really need a switch, you can make this decision from other user inputs.
Mike
(2,929 Views)
I think i get it now.
Thank for all the help
(2,917 Views)
