Is it possible to change the Cursors appearance in a Graph?
i'm searching a method to change the Cursors appearce in a Graph or Plot,
espeacialy the diameter of the dot-Cursor should be increased.
greeting
N.Schnitzler
(2,849 Views)
Hi N.Schnitzler,
you can change the attribute of the cursor, there is a dot style section if you right click on the cursor in the cursor legend -> attribute -> the third from top.
Mike
(2,848 Views)
I know,
but i want to increase the diameter of the dot.
(2,838 Views)
You can play around with the Cursor Style, Cursor Point Style, and Line Width to get something like that, though there's no direct means to change the diameter. At least as far as I can see in 8.2 - don't know about 8.5. Another technique that you can try is the one shown here.
(2,829 Views)
smercurio posted "Another technique that you can try is the one shown here. "
... And extending that idea the example I posted in this thread may be of use. It exploits the new feature of the graph that allows you to define one of the graph planes using an image.
Here is a preview.
Have fun,
Ben
(2,824 Views)
