Is it ok to use local variables within the same loop?
@billko wrote:
@David99999 wrote:
Would a channel writer/reader setup be better than a local variable for sharing data between loops?
Probably over a billion times better, but I didn't check the math on that.
I ran the numbers a while back and it's actually 1,000,000,000.33 (repeating, of course).
Message 11 of 22
(1,505 Views)
Channel wires were created to communicate between loops and they do it really well. Start here. I use them all the time for simple tasks like this and for much more complex message/actor-based architectures, and they always do their job, as well as make the code more readable.
Certified LabVIEW Architect
Message 12 of 22
(1,475 Views)
That depends on the channel wire type.
If you use a 'tag' channel wire (basically a current value), I don't think there's much difference regarding race conditions.
But once you start putting things in sub VIs (not possible with locals), at least you have a wire to track.
If you use a messenger or stream, the loops are synchronized, and you probably might as well use 1 loop.
Message 13 of 22
(1,464 Views)
I don't believe this is true.
What about a stream in a Producer/Consumer or SMH architecture?
=== Engineer Ambiguously ===
Message 14 of 22
(1,424 Views)
I think Wiebe went too generic in his comment.  From other conversations I have had with him, I'm pretty sure he was trying to refer to "Synchronous Communication" where loop 1 sends a command/request to loop 2 and then waits for a reply.  This is a form of synchronization that would make one think about if multiple loops is actually needed.
Message 15 of 22
(1,404 Views)
In the context of the use case OP is picturing...
example
instead of a local, use a stream\messenger channel wire between two loops makes little sense (to me)...
Message 16 of 22
(1,382 Views)
wiebe@CARYA wrote:
In the use case OP is picturing...
Sure, but the OP's cases are not real world cases.
But they are common mistakes of using locals
Message 17 of 22
(1,374 Views)
I concur...
Message 18 of 22
(1,348 Views)
Local variable is not advisable to use inside the same loop. Instead you can use Functional Global variable. i have attached a reference of your code based on FGV. kindly refer that.
Message 19 of 22
(1,249 Views)
While an FGV would work here, it is completely unjustified. Just use the wire. Think dataflow!
Message 20 of 22
(1,238 Views)
