Is it a bug or what?
Please find the attached VI, its pretty simple function but its behaviour is unexpected.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,504 Views)
Accepted by topic author moderator1983
Probably not a bug.  Maybe a little lacking in the documentation area.
Don't use \ codes display in the Pattern input.  Use a normal string.
Your first pattern should be [\r][\n]\*\*Stop\*\*.
Your second pattern should be \*\*Stop\*\*.
(2,491 Views)
Thank you. Smiley Happy
(2,484 Views)
It's not a bug! The Match Pattern function allows to use some special characters such as the "*" that are interpretated from the function like "the rest of the string". If you want the function works properly before these specials characters you have to insert a "\" character to indicate to the function that that is a normal char. See your VI modified to understand how the function works.
Ricky
Italian Developer engineer
www.www.selt-sistemi.com
(2,477 Views)
