Open Spreadsheet Message
After creating a spreadsheet file using the Write to Spreadsheet File.vi I get the attached message when opening the resulting file.  In other words I get this message when opening the file using Excel.  I’ve set the program to save the files with the XLS extension.  The file opens OK if I click Yes.
I cannot open the resulting spreadsheet if I use the XLSX extension.
I’m using LV 2010 SP1, Win-XP and Excel v. 2007.
How do I avoid getting the above message and why does it not work when using the XLSX extension?
(3,061 Views)
You should be aware that you are actually creating a text file and not an actual xls document. It happens that Excel is happy to read a comma or tab separated spreadshheet file but it is obvious that the format is different.
I've never tried naming a text file with the xlsx extension but since the format is not even close to the xml format, I'm not a bit surprise it will not open correctly. That would be a question for Microsoft. Nothing at all to do with LabVIEW.
(3,055 Views)
Take a look in this thread and see if it can be of any help. If you want to use .xlsx / .xls / .csv there is no problem using the Free Excel Toolkit described in that thread. There are also some examples there and how to use the toolkit. It's a very useful tool if you don't have to MS Office report generation toolkit.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,042 Views)
Hi Dennis,
I would have thought that saving a file using the write to spreadsheet function would be writing a spreadsheet file. Thank you for clarifying that it's a text file.  I've explained to the end user to save it as a spreadshee file (XLSX) after opening and then there's no pop-up message later when they open it again.
Dave
(3,019 Views)
