Is control in subvi wired?
Just wandering if there is a way for a sub vi to tell if a control is wired when it was called.  I know that if it is not called it will use the default value.
So if I have a Boolean control as an input to a vi, I want to know inside the vi whether the terminal was wired or not.  I know it will get the default value that I set up in the vi for the control if it is not wired.  I've looked for a property of the control using a reference but didn't see anything obvious.
Mike
Message 1 of 10
(4,216 Views)
If it is really important to you, post a suggestion on the idea exchange:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/idb-p/labviewideas
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 3 of 10
(4,205 Views)
OK.  Thanks for the quick response.  I couldn't find those when I searched.
Mike
Message 4 of 10
(4,204 Views)
You can use a variant control, and check if it's void.
Message 5 of 10
(4,186 Views)
...or just mark the input as required thereby removing all doubts.
Ben
"A wise man  may keep silent and appear a fool, while a fool speaks his mind and removes all doubts" (Paraphrase Proverbs)
Message 6 of 10
(4,177 Views)
What I do is to make the default value of the control something that is very unlikely to be sent to the subvi. If it is a string make the default value something like "this-control-is-not-wired-because-this-is-the-default-value". If it is a number then make the default value way outside of the range you expect. You could make it NaN if you do not expect that.
LabVIEW 2012
Message 7 of 10
(4,163 Views)
I am not one to take no for an answer, so I played around with this once.  The return on hacking investment is very small.  I can now do this quite easily with XNodes...
BUT
My personal opinion is that this is a TERRIBLE appproach, and it is annoying almost everywhere LV uses it.  (It is ok for array indexing functions, but there are still better ways IMO).   My classic peeve are the file functions which give you a dialog when the input is unwired: I could save many, many case structures and Express VIs if that same dialog would be triggered by an empty path or Not a Path, but no, only by wiring or unwiring the input.  Not exactly a Game-time decision.
My advice is to limit your decision making to what is inside the wires, not the absence or presence of wires.  The usual tricks are making default values "bad" (NaN for floats, Not a Path, Empty Strings) and just do the normal checking you always do for validity of inputs, regardless of the source.  Making the input required is also a useful suggestion, particularly for booleans which don't have a 'bad' value.
Message 8 of 10
(4,161 Views)
That's what I was thinking for strings, DBLs, path's and such.  Just not many choices when dealing with a Boolean to find a value I am unlikely to use. 🙂
Message 9 of 10
(4,158 Views)
See the link in my signature for a thread where Jim Kring suggested using wrappers...
If you have a VI that can be used in different ways but you want to enusre it is called corectly every time, then create a wrapper that does the correct call and make the connctors on the wrapper required. The required makes the user provide the info you need and the wrapper will ensure the sub-VI is called appropriately.
You can even go another step and put it all in a library and mark the wrappers as public to force others to use the wrappers.
Ben
Message 10 of 10
(4,143 Views)
