"Ben" wrote in message
news:506500000005000000408F0000-1027480788000@exchange.ni.com...
> Hi Swifty,
> If your current amp requires less of everything the teh DAQ-1200
> supplies, you should not have to add any thing other than maybe a
> fuse, just to be sure.
> Make sure you look at all of the spec's. Including peak and max
> values.
> Ben
Although it is indeed not absolutely required it is a very bad idea not to
use galvanic
isolation between your DAQ card and a 200 V output amp unless the amp has
already galvanic isolation built in. If the amp breaks and sources its full
voltage to the
DAQ card you not only get a destroyed DAQ card AND computer but possible
claims for injury of the operator who happened to sit at the computer at the
time
the amp blew up.
Rolf
