Is Visa Open / Close needed?
when sending scpi commands to an instrument then i can simply use the Visa_Write and it works.
Why is there also a Visa_Open and Visa_Close?
(8,282 Views)
I know one element is VISA open and close will manage the reservation of hardware ports.
If you run the application just with VISA write then the port get reserved. I think if you then try and access it from another application you will find that the reservation is held and it can't be accessed. This can also happen between runs of VIs. For this reason it is good practice.
Open will allow you to make configuration changes on the port before the write if needed and also reduce the work done when you have write. i.e. if you have no open then any "open" operations must happen for every write where as if you have a separate open you can do it once at the start of your application and reduce overhead (as well as making sure you have the hardware reserved properly so there will be no errors once your application is running._.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(8,268 Views)
Hi OnlyOne,
when trying to allocate/use a shared resource (like a communication port with an external device) you should open/request that resource and close/free it afterwards! (Additionally you might want to set parameters of the communication port when opening it.)
Even when LabVIEW does this work for you in the background it will not arrange things for you in a magical way when it comes to things like parallel access to the same shared resource!
(8,266 Views)
Is it possible that each "write" creates a new session and that there is a "maximum number of sessions"?
It looks like that after running ~10-20 time the vi (without open/close) that it suddenly does not work anymore. After closing/opening labview everything runs fine again. Looks like there is a max number of sessions reached after that the write does not run anymore.
There is also a parameter in labview "auomatically close visa session" - perhaps this would solve this problem. (If there is a value for "max number of sessions")
(8,256 Views)
I dont think there is a maximum number of sessions other than 1 when the hardware is reserved.
It could be a race condition if you are using this port in more than one place. On 90% of connections there is no conflict but then in the 10% case two places access the port at the same time.
I would look to incorporate the open close so you can more explicitly managed the connection and go from there.
Cheers,
James
James Mc
(8,235 Views)
I think the Open is done behind the scenes with the first thing that accesses the port.  So for serial ports, we just use the VISA Configure Serial Port and that somehow opens (reserves) the port (nothing explicit inside of the VI to open it).  Then when done with the port, use VISA Close in order to release the hardware.  I hate the "auto close" and "auto error handling" options in LabVIEW because it makes people lazy and not think about these important things (resource management and error handling).
In conclusion: You really should be closing your resource when you are done with it.
(8,209 Views)
I have also noticed on some instruments if you do not close the VISA session the instrument is left in the "remote" state and all of it's front panel controls are locked out.
This can be a bad thing for instance on my AC source there is no "Local/Remote" button on the instrument so you have to power cycle it to regain control.
=== Engineer Ambiguously ===
(8,182 Views)
