Is SMA clock input supported in Spartan3E FPGA driver?
I am using Labview 8.6 FPGA module for Spartan3E board.  Is SMA clock input supported in Spartan3E FPGA driver?
If I use SMA clock input, Labview reports error (OnboardClock tag missing) when I compile VI. If I use both of two, it reports too much clock resources used.
Anyone can help this? Thanks.
Bynan
(2,973 Views)
The error message is:
Required tag was not found in the resource file.
Target name: FPGA Target (Dev1, Spartan-3E Starter Board)
Tag: OnboardClock
(2,964 Views)
