Ip Camera
Hi friends,
I have an İp camera (Panasonic SUD-638). And i want to take video stream. I searched a lot time and NI says "You can only use Basler's and Axis's Ip cameras. But i have only this camera. How can i take this video stream? Do you have any idea?(Sorry for bad English).
(3,200 Views)
If you are required to use that camera, you might need to contact NI and see if they can suggest whom you can hire to write an IMAQdx-compatible driver for it.  I've used both Axis and Basler IP cameras, myself, so another solution for you would be to obtain a LabVIEW-compatible camera from one of these two manufacturers.
(3,197 Views)
Is that possible to write an text or G code for another code language? If it is possible i can write and yes i have to use this camera.
(3,185 Views)
If your camera comes with DLLs that expose its functionality, you can write sub-VIs that call these DLLs (using the Call Library Function Node, found on the Connectivity Palette, Libraries and Executables sub-Palette).  I strongly suggest that you write such "wrapper" sub-VIs to "hide the messy details" of the camera's API and present a more "user-friendly" interface to yourself.
(3,174 Views)
I have some SDKs like C#, HTML ,C++. Can i run the C++ SDK correctly in Real Time? I run C# code with activex but activex does not work in Real Time. I attached a SDK. In SDK, PS-API has C++ codes. For example  want to use Pay Live file.Can i run this SDK in Real Time?
(3,163 Views)
